Datasheet Texas Instruments SN54LVTH162245-SP — Даташит
СерияSN54LVTH162245-SP
16-битные шинные трансиверы ABT 3,3 В с выходами с 3 состояниями
3.3-V ABT 16-BIT BUS TRANSCEIVERS WITH 3-STATE OUTPUTS--SN74LVTH162245 datasheet
PDF, 948 Кб, Версия: Q, Файл опубликован: 1 ноя 2006
5962-9678001VXA
Статус продуктаВ производстве
5962-9678001VXA
N1
Pin48
Package TypeWD
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Package QTY1
МаркировкаSNV54LVTH16224
Width (мм)9.66
Length (мм)15.88
Thickness (мм)2.48
Pitch (мм).635
Max Height (мм)3.05
Parameters / Models5962-9678001VXA
5962-9678001VXA
Bits16
Рабочий диапазон температур, Cот -55 до 125
Package GroupCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)
RatingSpace
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
5962-9678001VXA
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH162245-SP (1)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN54LVTH162245-SP
Публикации по теме
