Datasheet Texas Instruments SN54LVTH162373-SP — Даташит
СерияSN54LVTH162373-SP
3,3 В ABT, 16-битные прозрачные защелки D-типа с выходами с 3 состояниями
SN54LVTH162373, SN74LVTH162373 datasheet
PDF, 890 Кб, Версия: M, Файл опубликован: 1 дек 2006
5962-9763801VXA
Статус продуктаВ производстве
5962-9763801VXA
N1
Pin48
Package TypeWD
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Package QTY1
МаркировкаA
Width (мм)9.66
Length (мм)15.88
Thickness (мм)2.48
Pitch (мм).635
Max Height (мм)3.05
Parameters / Models5962-9763801VXA
5962-9763801VXA
3-State OutputYes
Bits16
F @ Nom Voltage(Max), Mhz160
ICC @ Nom Voltage(Max), мА5
Тип входаTTL
Рабочий диапазон температур, Cот -55 до 125
Output Drive (IOL/IOH)(Max), мА12/-12
Тип выходаTTL
Package GroupCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)
RatingSpace
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
tpd @ Nom Voltage(Max), нс4.6
5962-9763801VXA
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH162373-SP (1)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN54LVTH162373-SP
Публикации по теме
