Datasheet Texas Instruments 5962-9681001QXA — Даташит
СерияSN54LVTH16373
Модель5962-9681001QXA
3,3 В ABT, 16-битные прозрачные защелки D-типа с выходами с 3 состояниями 48-CFP от -55 до 125
SN54LVTH16373, SN74LVTH16373 datasheet
PDF, 944 Кб, Версия: P, Файл опубликован: 1 ноя 2006
Pin48484848
Package TypeWDWDWDWD
Industry STD TermCFPCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка5962-9681001QXSNJ54LVTH16373AWD
Width (мм)9.669.669.669.66
Length (мм)15.8815.8815.8815.88
Thickness (мм)2.482.482.482.48
Pitch (мм).635.635.635.635
Max Height (мм)3.053.053.053.05
3-State OutputYes
Bits16
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)64/-12 мА
Тип выходаTTL
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)3.8 нс
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH16373 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629681001QXA, 5962 9681001QXA
На английском языке: Datasheet Texas Instruments 5962-9681001QXA
