Datasheet Texas Instruments SN54LVTH16374 — Даташит
СерияSN54LVTH16374
16-битные триггеры D-типа ABT, 3,3 В, с триггером по фронту и выходами с 3 состояниями
3.3-V ABT 16-Bit Edge-Triggered D-Type Flip-Flops With 3-State Outputs datasheet
PDF, 766 Кб, Версия: R, Файл опубликован: 23 авг 2007
5962-9564701QXASNJ54LVTH16374WD
N12
Pin4848
Package TypeWDWD
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
МаркировкаSNJ54LVTH16374WD
Width (мм)9.669.66
Length (мм)15.8815.88
Thickness (мм)2.482.48
Pitch (мм).635.635
Max Height (мм)3.053.05
Parameters / Models5962-9564701QXA
5962-9564701QXA
SNJ54LVTH16374WD
SNJ54LVTH16374WD
3-State OutputYesYes
Bits1616
F @ Nom Voltage(Max), Mhz160160
ICC @ Nom Voltage(Max), мА55
Тип входаTTLTTL
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаTTLTTL
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
tpd @ Nom Voltage(Max), нс4.54.5
RoHSSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH16374 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN54LVTH16374
