Datasheet Texas Instruments SNJ54LVTH16501WD — Даташит
СерияSN54LVTH16501
МодельSNJ54LVTH16501WD
18-битные УНИВЕРСАЛЬНЫЕ ШИННЫЕ ТРАНСИВЕРЫ ABT 3,3 В С 3-СОСТОЯННЫМИ ВЫХОДАМИ 56-CFP от -55 до 125
SN54LVTH16501, SN74LVTH16501 datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 19 авг 2009
Pin56565656
Package TypeWDWDWDWD
Industry STD TermCFPCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка5962-9677701QXASNJ54LVTH16501WD
Width (мм)9.669.669.669.66
Length (мм)18.4218.4218.4218.42
Thickness (мм)2.482.482.482.48
Pitch (мм).635.635.635.635
Max Height (мм)3.053.053.053.05
Bits18
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL/CMOS
Output Drive (IOL/IOH)(Max)-24/+48 мА
Тип выходаCMOS
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.3 нс
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN54LVTH16501 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Universal Bus Function Products
На английском языке: Datasheet Texas Instruments SNJ54LVTH16501WD
