Datasheet Texas Instruments SN54LVTH16501 — Даташит
СерияSN54LVTH16501
18-битные УНИВЕРСАЛЬНЫЕ ШИННЫЕ ТРАНСИВЕРЫ ABT 3,3 В С 3-СОСТОЯННЫМИ ВЫХОДАМИ
SN54LVTH16501, SN74LVTH16501 datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 19 авг 2009
5962-9677701QXASNJ54LVTH16501WD
N12
Pin5656
Package TypeWDWD
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
МаркировкаWD5962-9677701QX
Width (мм)9.669.66
Length (мм)18.4218.42
Thickness (мм)2.482.48
Pitch (мм).635.635
Max Height (мм)3.053.05
Parameters / Models5962-9677701QXA
5962-9677701QXA
SNJ54LVTH16501WD
SNJ54LVTH16501WD
Bits1818
F @ Nom Voltage(Max), Mhz160160
ICC @ Nom Voltage(Max), мА55
Тип входаTTL/CMOSTTL/CMOS
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА-24/+48-24/+48
Тип выходаCMOSCMOS
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
Voltage(Nom), В3.33.3
tpd @ Nom Voltage(Max), нс4.34.3
RoHSSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH16501 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Universal Bus Function Products
На английском языке: Datasheet Texas Instruments SN54LVTH16501
