Datasheet Texas Instruments SN54LVTH16952 — Даташит
СерияSN54LVTH16952
16-битные зарегистрированные трансиверы ABT 3,3 В с 3-состоятельными выходами
3.3-V ABT 16-Bit Registered Transceivers With 3-State Outputs datasheet
PDF, 849 Кб, Версия: G, Файл опубликован: 10 апр 2000
5962-9684901QXASNJ54LVTH16952WD
N12
Pin5656
Package TypeWDWD
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
Маркировка5962-9684901QXSNJ54LVTH16952
Width (мм)9.669.66
Length (мм)18.4218.42
Thickness (мм)2.482.48
Pitch (мм).635.635
Max Height (мм)3.053.05
Parameters / Models5962-9684901QXA
5962-9684901QXA
SNJ54LVTH16952WD
SNJ54LVTH16952WD
Bits1616
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
RoHSSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH16952 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN54LVTH16952
