Datasheet Texas Instruments 5962-9681101QXA — Даташит
СерияSN54LVTH18502A
Модель5962-9681101QXA
Устройства сканирования ABT 3,3 В с 18-битными приемопередатчиками универсальной шины 68-CFP от -55 до 125
SN54LVTH18502A, SN54LVTH182502A, SN74LVTH18502A, SN74LVTH182502A datasheet
PDF, 890 Кб, Версия: C, Файл опубликован: 3 июн 2004
Pin68686868
Package TypeHVHVHVHV
Industry STD TermCFPCFPCFPCFP
JEDEC CodeS-GQFP-FS-GQFP-FS-GQFP-FS-GQFP-F
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка5962-9681101QXSNJ54LVTH18502AAHV
Width (мм)12.5112.5112.5112.51
Length (мм)12.5112.5112.5112.51
Thickness (мм)3.563.563.563.56
Pitch (мм).635.635.635.635
Max Height (мм)3.863.863.863.86
Bits18
ICC @ Nom Voltage(Max)24 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)64/-32 мА
Тип выходаTTL
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)4.9 нс
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH18502A (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Boundary Scan (JTAG)
59629681101QXA, 5962 9681101QXA
На английском языке: Datasheet Texas Instruments 5962-9681101QXA
