Datasheet Texas Instruments SN54LVTH18502A — Даташит
СерияSN54LVTH18502A
Устройства сканирования сканирования ABT 3,3 В с 18-битными универсальными шинными приемопередатчиками
SN54LVTH18502A, SN54LVTH182502A, SN74LVTH18502A, SN74LVTH182502A datasheet
PDF, 890 Кб, Версия: C, Файл опубликован: 3 июн 2004
5962-9681101QXASNJ54LVTH18502AHV
N12
Pin6868
Package TypeHVHV
Industry STD TermCFPCFP
JEDEC CodeS-GQFP-FS-GQFP-F
Package QTY11
CarrierTUBETUBE
Маркировка5962-9681101QXAHV
Width (мм)12.5112.51
Length (мм)12.5112.51
Thickness (мм)3.563.56
Pitch (мм).635.635
Max Height (мм)3.863.86
Parameters / Models5962-9681101QXA
5962-9681101QXA
SNJ54LVTH18502AHV
SNJ54LVTH18502AHV
Bits1818
ICC @ Nom Voltage(Max), мА2424
Тип входаTTLTTL
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаTTLTTL
Package GroupCFPCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)See datasheet (CFP)
RatingMilitaryMilitary
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
tpd @ Nom Voltage(Max), нс4.94.9
RoHSSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH18502A (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Boundary Scan (JTAG)
На английском языке: Datasheet Texas Instruments SN54LVTH18502A
