Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN54LVTH245A-SP — Даташит
СерияSN54LVTH245A-SP
Восьмеричные шинные трансиверы ABT 3,3 В с выходами с 3 состояниями
SN54LVTH245A, SN74LVTH245A datasheet
PDF, 1.5 Мб, Версия: T, Файл опубликован: 11 сен 2003
5962-9564201V2A5962-9564201VRA5962-9564201VSA
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНет
N123
Pin202020
Package TypeFKJW
Industry STD TermLCCCCDIPCFP
JEDEC CodeS-CQCC-NR-GDIP-TR-GDFP-F
Package QTY111
CarrierTUBETUBETUBE
Маркировка9564201V2ASNV54LVTH245AJ5962-9564201VS
Width (мм)8.896.926.92
Length (мм)8.8924.213.09
Thickness (мм)1.834.571.84
Pitch (мм)1.272.541.27
Max Height (мм)2.035.082.45
Parameters / Models5962-9564201V2A
5962-9564201V2A
5962-9564201VRA
5962-9564201VRA
5962-9564201VSA
5962-9564201VSA
Bits888
Рабочий диапазон температур, Cот -55 до 125от -55 до 125от -55 до 125
Package GroupLCCCCDIPCFP
Package Size: mm2:W x L, PKG20LCCC: 79 mm2: 8.89 x 8.89(LCCC)See datasheet (CDIP)See datasheet (CFP)
RatingSpaceSpaceSpace
Schmitt TriggerNoNoNo
Technology FamilyLVTLVTLVT
VCC(Max), В3.63.63.6
VCC(Min), В2.72.72.7
RoHSSee ti.comSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH245A-SP (3)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN54LVTH245A-SP
Публикации по теме
