Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 5962-9950901Q2A — Даташит
СерияSN54LVTH373
Модель5962-9950901Q2A
Восьмеричные прозрачные защелки ABT типа D, 3,3 В, с выходами с 3 состояниями 20-LCCC от -55 до 125
SN54LVTH373, SN74LVTH373 datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 13 окт 2003
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка9950901Q2A5962-SNJ54LVTH373FK
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
3-State OutputYes
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)64/-12 мА
Тип выходаTTL
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)3.9 нс
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629950901Q2A, 5962 9950901Q2A
На английском языке: Datasheet Texas Instruments 5962-9950901Q2A
