Datasheet Texas Instruments 5962-9583101QRA — Даташит
СерияSN54LVTH573
Модель5962-9583101QRA
3,3 В ABT Восьмеричные прозрачные защелки типа D с выходами с 3 состояниями 20-CDIP -55–125
SN54LVTH573, SN74LVTH573 datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 15 сен 2003
Pin202020
Package TypeJJJ
Industry STD TermCDIPCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-TR-GDIP-T
Package QTY111
CarrierTUBETUBETUBE
МаркировкаA5962-9583101QRSNJ54LVTH573J
Width (мм)6.926.926.92
Length (мм)24.224.224.2
Thickness (мм)4.574.574.57
Pitch (мм)2.542.542.54
Max Height (мм)5.085.085.08
3-State OutputYes
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)48/-24 мА
Тип выходаTTL
Package GroupCDIP
RatingMilitary
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)4.5 нс
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629583101QRA, 5962 9583101QRA
На английском языке: Datasheet Texas Instruments 5962-9583101QRA
