Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI 5962-9583201VSA — Даташит
СерияSN54LVTH574-SP
Модель5962-9583201VSA
Datasheet Texas Instruments 5962-9583201VSA
Восьмеричные триггеры D-типа ABT, 3,3 В, с триггером по фронту и выходами с 3 состояниями 20-CFP от -55 до 125
SN54LVTH574, SN74LVTH574 datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 15 сен 2003
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH574-SP (1)
  • 5962-9583201VSA
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629583201VSA, 5962 9583201VSA
На английском языке: Datasheet Texas Instruments 5962-9583201VSA
Публикации по теме
Политика конфиденциальности
