Datasheet ТI SN54LVTH574-SP — Даташит
СерияSN54LVTH574-SP
Datasheet Texas Instruments SN54LVTH574-SP
Восьмеричные триггеры D-типа ABT, 3,3 В, с триггером по фронту и выходами с 3 состояниями
SN54LVTH574, SN74LVTH574 datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 15 сен 2003
5962-9583201VSA
Статус продуктаВ производстве
5962-9583201VSA
N1
Pin20
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Package QTY25
МаркировкаSNV54LVTH574W
Width (мм)6.92
Length (мм)13.09
Thickness (мм)1.84
Max Height (мм)2.45
Parameters / Models5962-9583201VSA
5962-9583201VSA
3-State OutputYes
Bits8
F @ Nom Voltage(Max), Mhz160
ICC @ Nom Voltage(Max), мА5
Тип входаTTL
Рабочий диапазон температур, Cот -55 до 125
Output Drive (IOL/IOH)(Max), мА64/-32
Тип выходаTTL
Package GroupCFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)
RatingSpace
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
tpd @ Nom Voltage(Max), нс4.5
5962-9583201VSA
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH574-SP (1)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN54LVTH574-SP
Публикации по теме
Политика конфиденциальности
