Datasheet Texas Instruments SN6505ADBVT — Даташит
СерияSN6505A
МодельSN6505ADBVT
Малошумящий трансформаторный драйвер 1 А, 160 кГц с плавным пуском для изолированных источников питания 6-SOT-23 от -55 до 125
SN6505x Low-Noise 1-A Transformer Drivers for Isolated Power Supplies datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 18 апр 2019
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
Маркировка650A
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм)0.95
Max Height (мм)1.45
Approx. price0.86 | 1ku US$
Основные особенностиEnable,Short-circuit protection,Spread spectrum clocking,Thermal shutdown,Slew-rate control
Iout1 A
Iout(Max)1.5 A
Operating temperature range-55 to 125 C
Package size: mm2:W x L6SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|6) PKG
Soft startYes
Switch current limit(Typ)2 A
Switching frequency(Max)600 kHz
Switching frequency(Min)100 kHz
Vin(Max)5.5 В
Vin(Min)2.25 В
Vout(Max)16 В
  • Evaluation Modules & Boards: SN6505AEVM
    SN6505A low-noise 1-A transformer driver for isolated power supplies evaluation module (160-kHz CLK)
  • Signal and Power Isolation with 3.3 V / 5 V Input and 12 V / 15 V Output
    PDF, 404 Кб, Файл опубликован: 17 окт 2018
  • Isolated CAN Reference Design (Rev. C)
    PDF, 39 Кб, Версия: C, Файл опубликован: 14 сен 2018
    This design note presents the reference design of an isolated CAN node using the isolated CAN transceiver and a transformer driver SN6505A to generate the isolated power.
  • How to Isolate Signal and Power in Isolated CAN Systems
    PDF, 49 Кб, Файл опубликован: 14 май 2018
    With the increase in the usage of signal isolation in many industrial and automotive applications the need for isolated power has also increased. The benefits of isolation are lost if the power supplies on either side of the isolation barrier are simply shorted. At the same time if the isolated power sub-systems are not designed carefully it affects the overall system performance like temperatu
  • How to isolate signal and power for I2C (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 2 окт 2018
  • How to isolate signal and power for an RS-485 system (Rev. B)
    PDF, 67 Кб, Версия: B, Файл опубликован: 16 окт 2018
    he Telecommunications Industry Association (TIA) and Electronic Industries Alliance (EIA) standard for RS-485 communication was established two decades ago and has been widely adopted for a variety of applications. RS-485 is the ideal standard for reliable communication over long distances of 1000 meters because of the twisted pair structure used to send a differential signal.
Серия: SN6505A (2)
  • Semiconductors > Analog and Mixed-Signal > Isolation > Transformer drivers
На английском языке: Datasheet Texas Instruments SN6505ADBVT
