Datasheet Texas Instruments SN65HVD1040QDRQ1 — Даташит
СерияSN65HVD1040-Q1
МодельSN65HVD1040QDRQ1
Automotive Catalog EMC Optimized CAN Transceiver 8-SOIC -40 to 125
SN65HVD1040-Q1 EMC-Optimized Can Transceiver datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 19 сен 2016
40 предложений от 18 поставщиков
SN65HVD1040QDRQ1
от 28 ₽
Элитан
SN65HVD1040QDRQ1
217 ₽
SN65HVD1040QDRQ1
от 373 ₽
727GS
SN65HVD1040QDRQ1
Package TypeD
Package QTY2500
МаркировкаH1040Q
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Bus Fault Voltage-27 to 40 В
Common Mode Voltage-12 to 12 В
Основные особенностиHigh Speed,Bus Wake Up,Split Pin
HBM ESD12 kV
IEC 61000-4-2 Contact6 +/- kV
IsolatedNo
Low Power ModeStandby
ProtocolsCAN
RatingAutomotive
Signaling Rate(Max)1 Mbps
Supply Voltage(s)4.75 to 5.25 В
  • Common-Mode Chokes in CAN Networks: Source of Unexpected Transients
    PDF, 230 Кб, Файл опубликован: 29 янв 2008
    Common-mode chokes are frequently used in automotive CAN networks to increase system reliability with respect to electromagnetic compatibility (EMC). Electromagnetic interference emitted from an Electronic Control Module (ECU) through the CAN transceiver can be filtered, thus limiting unwanted high-frequency noise on the communication bus. Another reason for using a common-mode choke is attempting
Серия: SN65HVD1040-Q1 (1)
  • SN65HVD1040QDRQ1
  • Semiconductors > Interface > CAN/LIN
На английском языке: Datasheet Texas Instruments SN65HVD1040QDRQ1
Публикации по теме
