Datasheet Texas Instruments SN65HVDA540QDR — Даташит
СерияSN65HVDA540
МодельSN65HVDA540QDR
5-V CAN Transceiver With I/O Level Shifting and Supply Optimization 8-SOIC -40 to 125
5-V CAN Transceiver With I/O Level Shifting and Supply Optimization datasheet
PDF, 380 Кб, Файл опубликован: 8 май 2009
Package TypeD
Package QTY2500
МаркировкаA540Q
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Bus Fault Voltage-27 to 40 В
Common Mode Voltage-12 to 12 В
Основные особенностиHigh Speed,VIO Pin
HBM ESD12 kV
IEC 61000-4-2 Contact7 +/- kV
IsolatedNo
Low Power ModeStandby
ProtocolsCAN
Signaling Rate(Max)1 Mbps
Supply Voltage(s)4.75 to 5.25 В
  • Evaluation Modules & Boards: MMWAVE-DEVPACK
    mmWave Development Pack (DevPack)
  • Evaluation Modules & Boards: AWR1443BOOST
    AWR1443 Single-Chip 76-to-81GHz Automotive Radar Sensor Evaluation Module
  • Evaluation Modules & Boards: AWR1243BOOST
    AWR1243 76-to-81GHz High-Performance Automotive Radar Sensor Evaluation Module
  • Evaluation Modules & Boards: IWR1443BOOST
    IWR1443 Single-Chip 76-to-81GHz mmWave Sensor Evaluation Module
Серия: SN65HVDA540 (1)
  • SN65HVDA540QDR
  • Semiconductors > Interface > CAN/LIN
На английском языке: Datasheet Texas Instruments SN65HVDA540QDR
