Datasheet Texas Instruments SN65LV1224B-EP — Даташит
СерияSN65LV1224B-EP
Enhanced Product 1:10 Lvds Serdes Receiver 100-660 Mbps
SN65LV1023A-EP, SN65LV1224B-EP datasheet
PDF, 776 Кб, Файл опубликован: 20 сен 2006
SN65LV1224BMDBREPV62/06677-02XE
N12
Pin2828
Package TypeDBDB
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLV1224BMEPLV1224BMEP
Width (мм)5.35.3
Length (мм)10.210.2
Thickness (мм)1.951.95
Pitch (мм).65.65
Max Height (мм)22
Parameters / ModelsSN65LV1224BMDBREP
SN65LV1224BMDBREP
V62/06677-02XE
V62/06677-02XE
Data Throughput, Mb/s660660
Driver (RL), Ohms27,12027,120
Gbps per Serial Channel, Min0.660.66
ICC, мА8080
Number of Parallel Outputs1010
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output CompatibilityLVTTLLVTTL
PLL Frequency, МГц10 - 6610 - 66
Package GroupSSOPSSOP
Package Size: mm2:W x L, PKG28SSOP: 80 mm2: 7.8 x 10.2(SSOP)28SSOP: 80 mm2: 7.8 x 10.2(SSOP)
Power Consumption(Nom), mW450450
RatingHiRel Enhanced ProductHiRel Enhanced Product
Receiver (Vth), мВ5050
Serial Data Receiver Channels22
Signal ConditioningNoNo
Supply Voltage(s), В3.33.3
Type of Line CircuitLVDSLVDS
VCC(Max), В3.63.6
VCC(Min), В33
VCC(Nom), В3.33.3
VIH(Max), В3.63.6
VIH(Min), В22
VIL(Max), В0.80.8
RoHSСовместимСовместим
Серия: SN65LV1224B-EP (2)
  • Semiconductors> Space & High Reliability> Interface Products> Serializers, Deserializers
На английском языке: Datasheet Texas Instruments SN65LV1224B-EP
Публикации по теме
