Datasheet Texas Instruments SN65LVDM176DG4 — Даташит
СерияSN65LVDM176
МодельSN65LVDM176DG4
Полудуплексный трансивер LVDM 8-SOIC от -40 до 85
High-Speed Differential Line Transceiver datasheet
PDF, 933 Кб, Версия: D, Файл опубликован: 3 авг 2000
Package TypeD
Package QTY75
МаркировкаDM176
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Device TypeTransceiver
ESD HBM15 kV
FunctionTransceiver
ICC(Max)15 мА
Input SignalLVDM,LVTTL
No. of Rx1
No. of Tx1
Output SignalLVDM,LVTTL
ProtocolsLVDS
Signaling Rate400 Mbps
  • Transmission at 200 Mbps in VME Card Cage Using LVDM (Rev. A)
    PDF, 9.3 Мб, Версия: A, Файл опубликован: 4 янв 2002
    Test results at a TI LVDS Multipoint (LVDM) system show that a VME backplane with an LVDM electrical layer can support signaling rates to 200 Mbps. The performance of differential with the SN65LVDM176 transceiver is characterized using a commercially-available VME card cage. Test results show how changes in bus loading influence the electrical characteristcs of a backplane and the resulting re
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDM176DG4
