Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN65LVDS100D — Даташит
СерияSN65LVDS100
МодельSN65LVDS100D
2 Gbps LVDS/LVPECL/CML to LVDS Buffer/Repeater/Translator 8-SOIC -40 to 85
SN65LVDx10x Differential Translator/Repeater datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 20 июл 2015
Package TypeD
Package QTY75
МаркировкаDL100
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Device TypeBuffer
ESD HBM5 kV
FunctionRepeater/Translator
ICC(Max)30 мА
Input SignalCML,LVDS,LVPECL
No. of Rx1
No. of Tx1
Output SignalLVDS
ProtocolsLVDS
Signaling Rate2000 Mbps
  • Evaluation Modules & Boards: SN65LVDS100EVM
    SN65LVDS100 Evaluation Module
  • Evaluation Modules & Boards: SN65CML100EVM
    SN65CML100 Evaluation Module
  • Signaling Rate vs. Distance for Differential Buffers
    PDF, 420 Кб, Файл опубликован: 26 янв 2010
  • DC-Coupling Between Differential LVPECL, LVDS, HSTL, and CML
    PDF, 135 Кб, Файл опубликован: 19 фев 2003
  • AC Coupling Between Differential LVPECL, LVDS, HSTL and CML (Rev. C)
    PDF, 417 Кб, Версия: C, Файл опубликован: 17 окт 2007
    This report provides a quick reference of ac-coupling techniques for interfacing between different logic levels. The four differential signaling levels found in this reportare low-voltage positive-referenced emitter coupled logic (LVPECL), low-voltage differential signals (LVDS), high-speed transceiver logic (HSTL), and current-modelogic (CML). From these four differential signaling levels, 16
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS100D
