Datasheet Texas Instruments SN65LVDS100DGKG4 — Даташит
СерияSN65LVDS100
МодельSN65LVDS100DGKG4
Буфер/повторитель/транслятор LVDS/LVPECL/CML в LVDS 2 Гбит/с от -40 до 85
SN65LVDx10x Differential Translator/Repeater datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 20 июл 2015
Package TypeDGK
Industry STD TermVSSOP
Package QTY80
МаркировкаAZK
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Device TypeBuffer
ESD HBM5 kV
FunctionRepeater/Translator
ICC(Max)30 мА
Input SignalCML,LVDS,LVPECL
No. of Rx1
No. of Tx1
Output SignalLVDS
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
ProtocolsLVDS
Signaling Rate2000 Mbps
  • Evaluation Modules & Boards: SN65LVDS100EVM
    SN65LVDS100 Evaluation Module
  • Evaluation Modules & Boards: SN65CML100EVM
    SN65CML100 Evaluation Module
  • Signaling Rate vs. Distance for Differential Buffers
    PDF, 420 Кб, Файл опубликован: 26 янв 2010
  • DC-Coupling Between Differential LVPECL, LVDS, HSTL, and CML
    PDF, 135 Кб, Файл опубликован: 19 фев 2003
  • AC Coupling Between Differential LVPECL, LVDS, HSTL and CML (Rev. C)
    PDF, 417 Кб, Версия: C, Файл опубликован: 17 окт 2007
    This report provides a quick reference of ac-coupling techniques for interfacing between different logic levels. The four differential signaling levels found in this reportare low-voltage positive-referenced emitter coupled logic (LVPECL), low-voltage differential signals (LVDS), high-speed transceiver logic (HSTL), and current-modelogic (CML). From these four differential signaling levels, 16
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS100DGKG4
