Datasheet Texas Instruments SN65LVDS31PWR — Даташит
СерияSN65LVDS31
МодельSN65LVDS31PWR
Высокоскоростной дифференциальный драйвер LVDS Quad, 400 Мбит/с, 16-TSSOP от -40 до 85
SNx5LVDS31, SN65LVDS3487, SN65LVDS9638: High-Speed Differential Line Drivers datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 29 июл 2014
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVDS31
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Device TypeDriver
ESD HBM8 kV
FunctionDriver
ICC(Max)35 мА
Input SignalLVTTL
No. of Tx4
Output SignalLVDS
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
ProtocolsLVDS
Signaling Rate400 Mbps
  • Evaluation Modules & Boards: SN65LVDS31-32BEVM
    SN65LVDS31-32BEVM Evaluation Module for LVDS31 and LVDS32B
  • Evaluation Modules & Boards: SN65LVDS31-32EVM
    SN65LVDS31-32EVM Evaluation Module for LVDS31 and LVDS32
  • Evaluation Modules & Boards: SN65LVDS31-33EVM
    Evaluation Module for SN65LVDS31 and SN65LVDS33
  • Performance of LVDS with Different Cables (Rev. B)
    PDF, 246 Кб, Версия: B, Файл опубликован: 11 фев 2002
    This application report focuses on cable for use with LVDS devices rather than printed-circuit board interconnections. After a brief introduction to LVDS, the signal quality of seven different cables is evaluated using eye pattern measurements and TI's LVDS evaluation modules (EVMs). Since data transmission cable covers a wide range of cost and performance, this paper provides guidance for cable s
  • LVDS Multidrop Connections (Rev. A)
    PDF, 809 Кб, Версия: A, Файл опубликован: 11 фев 2002
    This application report describes design considerations for low-voltage differential swing (LVDS) multidrop connections. The report describes the maximum number of receivers possible versus signaling rate, signal quality, line length, output jitter, and common-mode voltage range when multidrop testing on a single LVDS line driver transmitting to numerous daisy-chained LVDS receivers.The LVDS rec
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS31PWR
