Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN65LVDS32DR — Даташит
СерияSN65LVDS32
МодельSN65LVDS32DR
Четырехскоростной дифференциальный приемник LVDS, 400 Мбит/с, 16-SOIC, от -40 до 85
SNx5LVDS32, SN65LVDS3486, SN65LVDS9637 High-Speed Differential Line Receivers datasheet
PDF, 1.9 Мб, Версия: R, Файл опубликован: 6 авг 2014
Pin16
Package TypeD
Package QTY2500
МаркировкаLVDS32
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Device TypeReceiver
ESD HBM8 kV
FunctionReceiver
ICC(Max)18 мА
Input SignalLVDS
No. of Rx4
Output SignalLVTTL
ProtocolsLVDS
Signaling Rate100 Mbps
  • Evaluation Modules & Boards: SN65LVDS31-32EVM
    SN65LVDS31-32EVM Evaluation Module for LVDS31 and LVDS32
  • Performance of LVDS with Different Cables (Rev. B)
    PDF, 246 Кб, Версия: B, Файл опубликован: 11 фев 2002
    This application report focuses on cable for use with LVDS devices rather than printed-circuit board interconnections. After a brief introduction to LVDS, the signal quality of seven different cables is evaluated using eye pattern measurements and TI's LVDS evaluation modules (EVMs). Since data transmission cable covers a wide range of cost and performance, this paper provides guidance for cable s
  • LVDS Multidrop Connections (Rev. A)
    PDF, 809 Кб, Версия: A, Файл опубликован: 11 фев 2002
    This application report describes design considerations for low-voltage differential swing (LVDS) multidrop connections. The report describes the maximum number of receivers possible versus signaling rate, signal quality, line length, output jitter, and common-mode voltage range when multidrop testing on a single LVDS line driver transmitting to numerous daisy-chained LVDS receivers.The LVDS rec
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS32DR
