Datasheet Texas Instruments SN65LVDS32BDR — Даташит
СерияSN65LVDS32B
МодельSN65LVDS32BDR
Приемник Quad LVDS с синфазным диапазоном от -2 до 4,4 В, 16-SOIC от -40 до 85
High-Speed Differential Receivers datasheet
PDF, 747 Кб, Версия: B, Файл опубликован: 23 апр 2007
Pin16
Package TypeD
Package QTY2500
МаркировкаLVDS32B
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Device TypeReceiver
ESD HBM15 kV
FunctionReceiver
ICC(Max)23 мА
Input SignalLVDS
No. of Rx4
Output SignalLVTTL
ProtocolsLVDS
Signaling Rate400 Mbps
  • Evaluation Modules & Boards: SN65LVDM31-32BEVM
    SN65LVDM31-32BEVM Evaluation Module
  • Evaluation Modules & Boards: SN65LVDS31-32BEVM
    SN65LVDS31-32BEVM Evaluation Module for LVDS31 and LVDS32B
  • Active Fail-Safe in TI's LVDS Receivers (Rev. B)
    PDF, 146 Кб, Версия: B, Файл опубликован: 31 окт 2001
    Differential line receivers commonly have fail-safe circuits to prevent the receiver from switching on input noise. Many innovative LVDS fail-safe solutions require either external components, with subsequent reduction in signal quality, or integrated solutions with limitedapplication. This paper addresses an innovative integrated fail-safe incorporated into the SN65LVDS32B receiver (hereafter r
Серия: SN65LVDS32B (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS32BDR
