Datasheet Texas Instruments SN65LVDS32B — Даташит
СерияSN65LVDS32B
Quad LVDS Receiver with -2 to 4.4V Common-mode Range
High-Speed Differential Receivers datasheet
PDF, 747 Кб, Версия: B, Файл опубликован: 23 апр 2007
SN65LVDS32BDSN65LVDS32BDG4SN65LVDS32BDR
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетДа
N123
Pin161616
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY40402500
CarrierTUBETUBELARGE T&R
МаркировкаLVDS32BLVDS32BLVDS32B
Width (мм)3.913.913.91
Length (мм)9.99.99.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Parameters / ModelsSN65LVDS32BD
SN65LVDS32BD
SN65LVDS32BDG4
SN65LVDS32BDG4
SN65LVDS32BDR
SN65LVDS32BDR
Device TypeReceiverReceiverReceiver
ESD HBM, kV151515
FunctionReceiverReceiverReceiver
ICC(Max), мА232323
Input SignalLVDSLVDSLVDS
No. of Rx444
Рабочий диапазон температур, Cот -40 до 85от -40 до 85от -40 до 85
Output SignalLVTTLLVTTLLVTTL
Package GroupSOICSOICSOIC
Package Size: mm2:W x L, PKG16SOIC: 59 mm2: 6 x 9.9(SOIC)16SOIC: 59 mm2: 6 x 9.9(SOIC)16SOIC: 59 mm2: 6 x 9.9(SOIC)
ProtocolsLVDSLVDSLVDS
Signaling Rate, Mbps400400400
  • Active Fail-Safe in TI's LVDS Receivers (Rev. B)
    PDF, 146 Кб, Версия: B, Файл опубликован: 31 окт 2001
    Differential line receivers commonly have fail-safe circuits to prevent the receiver from switching on input noise. Many innovative LVDS fail-safe solutions require either external components, with subsequent reduction in signal quality, or integrated solutions with limitedapplication. This paper addresses an innovative integrated fail-safe incorporated into the SN65LVDS32B receiver (hereafter r
Серия: SN65LVDS32B (3)
  • Semiconductors> Interface> LVDS/M-LVDS/ECL/CML> LVDS PHY (<800Mbps)
На английском языке: Datasheet Texas Instruments SN65LVDS32B
