Datasheet Texas Instruments SN65LVDS349PW — Даташит
СерияSN65LVDS349
МодельSN65LVDS349PW
Quad High Speed Differential Receivers 16-TSSOP -40 to 85
Quad High-Speed Differential Receiver datasheet
PDF, 835 Кб, Файл опубликован: 14 сен 2010
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаDL349
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Device TypeReceiver
ESD HBM15 kV
FunctionReceiver
ICC(Max)20 мА
Input SignalCMOS,ECL,LVCMOS,LVDS,LVECL,LVPECL,PECL
No. of Rx4
Output SignalLVTTL
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
ProtocolsLVDS
Signaling Rate560 Mbps
  • SN65LVDS348 vs SN65LVDS349
    PDF, 41 Кб, Файл опубликован: 5 окт 2010
    SN65LVDS348 and SN65LVDS349 are high-speed, quadruple differential receivers with a wide, common-mode, input voltage range of –4 V to 5 V. Both these devices meet or exceed the requirements of the ANSI TIA/EIA-644A standard. This document compares the two devices.
Серия: SN65LVDS349 (2)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS349PW
