Datasheet Texas Instruments SN65LVDS386DGGRG4 — Даташит
СерияSN65LVDS386
МодельSN65LVDS386DGGRG4
16-канальный приемник LVDS 64-TSSOP от -40 до 85
High-Speed Differential Line Receivers. datasheet
PDF, 1.7 Мб, Версия: I, Файл опубликован: 29 июл 2014
Pin64
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVDS386
Width (мм)6.1
Length (мм)17
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Device TypeReceiver
ESD HBM15 kV
FunctionReceiver
ICC(Max)70 мА
Input SignalLVDS
No. of Rx16
Output SignalLVTTL
Package GroupTSSOP
Package Size: mm2:W x L64TSSOP: 138 mm2: 8.1 x 17(TSSOP) PKG
ProtocolsLVDS
Signaling Rate250 Mbps
  • Evaluation Modules & Boards: SN65LVDS386EVM
    16-channel LVDS Receiver Evaluation Module
  • Using Signaling Rate and Transfer Rate (Rev. A)
    PDF, 258 Кб, Версия: A, Файл опубликован: 7 фев 2005
    This document defines data signaling rate and data transfer rate, and it demonstrates the differences between them. Taking the SN65LVDS386 and SN65LVDS387 16-channellow-voltage differential (LVDS) line drivers and receivers with random parallel data of various bandwidths as an example, this document discusses the components that make up the system timing budget and presents empirical data on cro
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS386DGGRG4
