Datasheet Texas Instruments SN65LVDS386 — Даташит
СерияSN65LVDS386
16-Channel LVDS Receiver
High-Speed Differential Line Receivers. datasheet
PDF, 1.7 Мб, Версия: I, Файл опубликован: 29 июл 2014
SN65LVDS386DGGSN65LVDS386DGGG4SN65LVDS386DGGRSN65LVDS386DGGRG4
Статус продуктаВ производствеВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНетНет
N1234
Pin64646464
Package TypeDGGDGGDGGDGG
Industry STD TermTSSOPTSSOPTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY252520002000
CarrierTUBETUBELARGE T&RLARGE T&R
МаркировкаLVDS386LVDS386LVDS386LVDS386
Width (мм)6.16.16.16.1
Length (мм)17171717
Thickness (мм)1.151.151.151.15
Pitch (мм).5.5.5.5
Max Height (мм)1.21.21.21.2
Parameters / ModelsSN65LVDS386DGG
SN65LVDS386DGG
SN65LVDS386DGGG4
SN65LVDS386DGGG4
SN65LVDS386DGGR
SN65LVDS386DGGR
SN65LVDS386DGGRG4
SN65LVDS386DGGRG4
Device TypeReceiverReceiverReceiverReceiver
ESD HBM, kV15151515
FunctionReceiverReceiverReceiverReceiver
ICC(Max), мА70707070
Input SignalLVDSLVDSLVDSLVDS
No. of Rx16161616
Рабочий диапазон температур, Cот -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output SignalLVTTLLVTTLLVTTLLVTTL
Package GroupTSSOPTSSOPTSSOPTSSOP
Package Size: mm2:W x L, PKG64TSSOP: 138 mm2: 8.1 x 17(TSSOP)64TSSOP: 138 mm2: 8.1 x 17(TSSOP)64TSSOP: 138 mm2: 8.1 x 17(TSSOP)64TSSOP: 138 mm2: 8.1 x 17(TSSOP)
ProtocolsLVDSLVDSLVDSLVDS
Signaling Rate, Mbps250250250250
RoHSСовместимСовместимСовместимСовместим
  • Using Signaling Rate and Transfer Rate (Rev. A)
    PDF, 258 Кб, Версия: A, Файл опубликован: 7 фев 2005
    This document defines data signaling rate and data transfer rate, and it demonstrates the differences between them. Taking the SN65LVDS386 and SN65LVDS387 16-channellow-voltage differential (LVDS) line drivers and receivers with random parallel data of various bandwidths as an example, this document discusses the components that make up the system timing budget and presents empirical data on cro
  • Semiconductors> Interface> LVDS/M-LVDS/ECL/CML> LVDS PHY (<800Mbps)
На английском языке: Datasheet Texas Instruments SN65LVDS386
