Datasheet Texas Instruments SN65LVDS387DGGRG4 — Даташит
СерияSN65LVDS387
МодельSN65LVDS387DGGRG4
16-канальный драйвер LVDS 64-TSSOP от -40 до 85
SNx5LVDS3xx High-Speed Differential Line Drivers datasheet
PDF, 1.5 Мб, Версия: G, Файл опубликован: 14 янв 2016
Pin64
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVDS387
Width (мм)6.1
Length (мм)17
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Device TypeDriver
ESD HBM15 kV
FunctionDriver
ICC(Max)95 мА
Input SignalLVTTL
No. of Tx16
Output SignalLVDS
Package GroupTSSOP
Package Size: mm2:W x L64TSSOP: 138 mm2: 8.1 x 17(TSSOP) PKG
ProtocolsLVDS
Signaling Rate630 Mbps
  • Evaluation Modules & Boards: SN65LVDS387EVM
    16-channel LVDS Driver Evaluation Module
  • Using Signaling Rate and Transfer Rate (Rev. A)
    PDF, 258 Кб, Версия: A, Файл опубликован: 7 фев 2005
    This document defines data signaling rate and data transfer rate, and it demonstrates the differences between them. Taking the SN65LVDS386 and SN65LVDS387 16-channellow-voltage differential (LVDS) line drivers and receivers with random parallel data of various bandwidths as an example, this document discusses the components that make up the system timing budget and presents empirical data on cro
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65LVDS387DGGRG4
