Datasheet Texas Instruments SN65MLVD203DG4 — Даташит
СерияSN65MLVD203
МодельSN65MLVD203DG4
Полнодуплексный трансивер M-LVDS 14-SOIC от -40 до 85
Multipoint-LVDS Line Driver and Receiver datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 7 янв 2008
Pin14
Package TypeD
Package QTY50
МаркировкаMLVD203
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Device TypeTransceiver
ESD HBM8 kV
FunctionTransceiver
ICC(Max)24 мА
Input SignalLVTTL,M-LVDS
No. of Rx1
No. of Tx1
Output SignalLVTTL,M-LVDS
ProtocolsM-LVDS
Signaling Rate200 Mbps
  • Evaluation Modules & Boards: MLVD20XEVM
    M-LVDS Evaluation Module
  • Wired-Logic Signaling with M-LVDS
    PDF, 322 Кб, Файл опубликован: 31 окт 2002
    M-LVDS devices provide true multipoint functionality. M-LVDS standard contention provisions and Type-2 M-LVDS receivers allow user of these devices in wired-logic signaling designs. This application report discusses M-LVDS features that support wired-logic signaling, compares this to LVDS features, and demonstrates wired-OR signaling with Texas Instruments M-LVDS complaint transceivers.
  • M-LVDS Signaling Rate Versus Distance
    PDF, 77 Кб, Файл опубликован: 9 апр 2003
    Multipoint LVDS (M-LVDS) devices provide a new class of high-speed, low-power, and standarized interface solutions. This report gives a brief review of TIA/EIA-899 (M-LVDS) and discusses the characteristics that affect the maximum signaling rate and distance. Maximum signaling rates are measured over 3-m, 10-m, 20-m, and 40-m lengths of CAT5 unshielded twisted pair (UTP) cable using the SN65MLVD
  • Interoperability of M-LVDS and BusLVDS
    PDF, 44 Кб, Файл опубликован: 6 фев 2003
    M-LVDS is standardized in TIA/EIA-899 to enable interoperability of compliant interface circuits, such as the SN65MLVD200 from Texas Instruments. This report compares data sheet specifications, and makes a conclusion on the interoperability of the nonstandard BusLVDS (BLVDS) DS92LV010A from National Semiconductor and the SN65MLVD200.
  • Introduction to M-LVDS (TIA/EIA-899) (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 3 янв 2013
  • TIA/EIA-485 and M-LVDS, Power and Speed Comparison
    PDF, 33 Кб, Файл опубликован: 20 фев 2002
    This document includes 3.3 V RS-485 and 3.3 V M-LVDS test data to demonstrate that M-LVDS provides low power multipoint operation and faster signaling rates (speeds) than RS-485.
Серия: SN65MLVD203 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments SN65MLVD203DG4
