Datasheet Texas Instruments SN65MLVD203 — Даташит
Серия | SN65MLVD203 |
Полнодуплексный трансивер M-LVDS
Multipoint-LVDS Line Driver and Receiver datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 7 янв 2008
SN65MLVD203D | SN65MLVD203DG4 | SN65MLVD203DR | |
Статус продукта | В производстве | В производстве | В производстве |
Доступность образцов у производителя | Да | Да | Нет |
N | 1 | 2 | 3 |
Pin | 14 | 14 | 14 |
Package Type | D | D | D |
Industry STD Term | SOIC | SOIC | SOIC |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 50 | 50 | 2500 |
Carrier | TUBE | TUBE | LARGE T&R |
Маркировка | MLVD203 | MLVD203 | MLVD203 |
Width (мм) | 3.91 | 3.91 | 3.91 |
Length (мм) | 8.65 | 8.65 | 8.65 |
Thickness (мм) | 1.58 | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 | 1.75 |
Parameters / Models | SN65MLVD203D![]() | SN65MLVD203DG4![]() | SN65MLVD203DR![]() |
Device Type | Transceiver | Transceiver | Transceiver |
ESD HBM, kV | 8 | 8 | 8 |
Function | Transceiver | Transceiver | Transceiver |
ICC(Max), мА | 24 | 24 | 24 |
Input Signal | LVTTL,M-LVDS | LVTTL,M-LVDS | LVTTL,M-LVDS |
No. of Rx | 1 | 1 | 1 |
No. of Tx | 1 | 1 | 1 |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Signal | LVTTL,M-LVDS | LVTTL,M-LVDS | LVTTL,M-LVDS |
Package Group | SOIC | SOIC | SOIC |
Package Size: mm2:W x L, PKG | 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) |
Protocols | M-LVDS | M-LVDS | M-LVDS |
Signaling Rate, Mbps | 200 | 200 | 200 |
- Wired-Logic Signaling with M-LVDSPDF, 322 Кб, Файл опубликован: 31 окт 2002
M-LVDS devices provide true multipoint functionality. M-LVDS standard contention provisions and Type-2 M-LVDS receivers allow user of these devices in wired-logic signaling designs. This application report discusses M-LVDS features that support wired-logic signaling, compares this to LVDS features, and demonstrates wired-OR signaling with Texas Instruments M-LVDS complaint transceivers. - M-LVDS Signaling Rate Versus DistancePDF, 77 Кб, Файл опубликован: 9 апр 2003
Multipoint LVDS (M-LVDS) devices provide a new class of high-speed, low-power, and standarized interface solutions. This report gives a brief review of TIA/EIA-899 (M-LVDS) and discusses the characteristics that affect the maximum signaling rate and distance. Maximum signaling rates are measured over 3-m, 10-m, 20-m, and 40-m lengths of CAT5 unshielded twisted pair (UTP) cable using the SN65MLVD - Interoperability of M-LVDS and BusLVDSPDF, 44 Кб, Файл опубликован: 6 фев 2003
M-LVDS is standardized in TIA/EIA-899 to enable interoperability of compliant interface circuits, such as the SN65MLVD200 from Texas Instruments. This report compares data sheet specifications, and makes a conclusion on the interoperability of the nonstandard BusLVDS (BLVDS) DS92LV010A from National Semiconductor and the SN65MLVD200. - Introduction to M-LVDS (TIA/EIA-899) (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 3 янв 2013
- TIA/EIA-485 and M-LVDS, Power and Speed ComparisonPDF, 33 Кб, Файл опубликован: 20 фев 2002
This document includes 3.3 V RS-485 and 3.3 V M-LVDS test data to demonstrate that M-LVDS provides low power multipoint operation and faster signaling rates (speeds) than RS-485.
Серия: SN65MLVD203 (3)
- Semiconductors> Interface> LVDS/M-LVDS/ECL/CML> Multipoint LVDS (MLVDS/BLVDS/LVDM)
