Datasheet Texas Instruments SN65MLVD207D — Даташит
| Серия | SN65MLVD207 |
| Модель | SN65MLVD207D |
Полнодуплексный трансивер M-LVDS 14-SOIC от -40 до 85
Multipoint-LVDS Line Driver and Receiver datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 7 янв 2008
Купить SN65MLVD207D на РадиоЛоцман.Цены — от 50 до 485 ₽43 предложений от 19 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| SN65MLVD207D Texas Instruments | 209 ₽ | ||
| SN65MLVD207D Texas Instruments | 300 ₽ | ||
| SN65MLVD207D | по запросу | ||
| Pin | 14 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | MLVD207 |
| Width (мм) | 3.91 |
| Length (мм) | 8.65 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Device Type | Transceiver |
| ESD HBM | 8 kV |
| Function | Transceiver |
| ICC(Max) | 24 мА |
| Input Signal | LVTTL,M-LVDS |
| No. of Rx | 1 |
| No. of Tx | 1 |
| Output Signal | LVTTL,M-LVDS |
| Package Group | SOIC |
| Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
| Protocols | M-LVDS |
| Signaling Rate | 200 Mbps |
- Evaluation Modules & Boards: MLVD20XEVM
M-LVDS Evaluation Module
- Wired-Logic Signaling with M-LVDSPDF, 322 Кб, Файл опубликован: 31 окт 2002
M-LVDS devices provide true multipoint functionality. M-LVDS standard contention provisions and Type-2 M-LVDS receivers allow user of these devices in wired-logic signaling designs. This application report discusses M-LVDS features that support wired-logic signaling, compares this to LVDS features, and demonstrates wired-OR signaling with Texas Instruments M-LVDS complaint transceivers. - M-LVDS Signaling Rate Versus DistancePDF, 77 Кб, Файл опубликован: 9 апр 2003
Multipoint LVDS (M-LVDS) devices provide a new class of high-speed, low-power, and standarized interface solutions. This report gives a brief review of TIA/EIA-899 (M-LVDS) and discusses the characteristics that affect the maximum signaling rate and distance. Maximum signaling rates are measured over 3-m, 10-m, 20-m, and 40-m lengths of CAT5 unshielded twisted pair (UTP) cable using the SN65MLVD - Interoperability of M-LVDS and BusLVDSPDF, 44 Кб, Файл опубликован: 6 фев 2003
M-LVDS is standardized in TIA/EIA-899 to enable interoperability of compliant interface circuits, such as the SN65MLVD200 from Texas Instruments. This report compares data sheet specifications, and makes a conclusion on the interoperability of the nonstandard BusLVDS (BLVDS) DS92LV010A from National Semiconductor and the SN65MLVD200. - Introduction to M-LVDS (TIA/EIA-899) (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 3 янв 2013
- TIA/EIA-485 and M-LVDS, Power and Speed ComparisonPDF, 33 Кб, Файл опубликован: 20 фев 2002
This document includes 3.3 V RS-485 and 3.3 V M-LVDS test data to demonstrate that M-LVDS provides low power multipoint operation and faster signaling rates (speeds) than RS-485.
Серия: SN65MLVD207 (4)
- SN65MLVD207D SN65MLVD207DG4 SN65MLVD207DR SN65MLVD207DRG4
- Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
