Datasheet Texas Instruments SN74ABT5403 — Даташит
СерияSN74ABT5403
12-битные драйверы линии/памяти с выходами с 3 состояниями
12-Bit Line/Memory Drivers With 3-State Outputs datasheet
PDF, 299 Кб, Версия: B, Файл опубликован: 1 янв 1997
SN74ABT5403DWR
Статус продуктаВ производстве
SN74ABT5403DWR
N1
Pin28
Package TypeDW
Package QTY1000
МаркировкаABT5403
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
Parameters / ModelsSN74ABT5403DWR
SN74ABT5403DWR
Bits12
F @ Nom Voltage(Max), Mhz150
ICC @ Nom Voltage(Max), мА0.05
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА-12/12
Package Size: mm2:W x L, PKG28SOIC: 184 mm2: 10.3 x 17.9(SOIC)
Schmitt TriggerNo
Technology FamilyABT
VCC(Max), В5.5
VCC(Min), В4.5
Voltage(Nom), В5
tpd @ Nom Voltage(Max), нс6.9
SN74ABT5403DWR
  • Quad Flatpack No-Lead Logic Packages (Rev. D)
    PDF, 1.0 Мб, Версия: D, Файл опубликован: 16 фев 2004
    Texas Instruments (TI) Quad Flatpack No-lead (QFN) 14/16/20-terminal Pb-free plastic packages meet dimensions specified in JEDEC standard MO-241 allow for board miniaturization and hold several advantages over traditional SOIC SSOP TSSOP and TVSOP packages. The packages are physically smaller have a smaller routing area improved thermal performance and improved electrical parasitics while
  • Advanced BiCMOS Technology (ABT) Logic Characterization Information (Rev. B)
    PDF, 528 Кб, Версия: B, Файл опубликован: 1 июн 1997
    The purpose of this document is to assist the designers of high-performance digital logic systems in using the advanced BiCMOS technology (ABT) logic family. Detailed electrical characteristics of these bus-interface devices are provided and tables and graphs have been included to compare specific parameters of the ABT family with those of other logic families. In addition typical data is provide
  • Advanced BiCMOS Technology (ABT) Logic Enables Optimal System Design (Rev. A)
    PDF, 115 Кб, Версия: A, Файл опубликован: 1 мар 1997
    Advanced bus-interface logic (ABIL) products processed in submicron advanced BiCMOS technologies (ABT) address the specific end-equipment demands of workstations personal and portable computers and telecommunications markets. This document discusses ABIL as system bus interfaces the merits of ABT its I/O structure packaging and ABT products for end-equipment specific solutions.
  • Family of Curves Demonstrating Output Skews for Advanced BiCMOS Devices (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 1 дек 1996
    This document shows the output skew for the ABT16254 ABT16952 and ABT16500A devices of the TI advanced BiCMOS (ABT) family. The data samples show which output skew is being examined where the data originates and how it is analyzed. Some errors present in the data are discussed. Skew curves at varying temperatures are given for the ABT16240 ABT16245 ABT16952 ABT16500A and ABT16249 devic
Серия: SN74ABT5403 (1)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74ABT5403
