Datasheet Texas Instruments SN74ABTH162245 — Даташит
СерияSN74ABTH162245
16-битные шинные трансиверы с выходами с 3 состояниями
16-Bit Bus Transceivers With 3-State Outputs datasheet
PDF, 312 Кб, Версия: A, Файл опубликован: 15 апр 1999
SN74ABTH162245DGGRSN74ABTH162245DL
N12
Pin4848
Package TypeDGGDL
Industry STD TermTSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY200025
CarrierLARGE T&RTUBE
МаркировкаABTH162245ABTH162245
Width (мм)6.17.49
Length (мм)12.515.88
Thickness (мм)1.152.59
Pitch (мм).5.635
Max Height (мм)1.22.79
Parameters / ModelsSN74ABTH162245DGGR
SN74ABTH162245DGGR
SN74ABTH162245DL
SN74ABTH162245DL
Bits1616
F @ Nom Voltage(Max), Mhz150150
ICC @ Nom Voltage(Max), мА0.0320.032
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА-32/64-32/64
Package GroupTSSOPSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)48SSOP: 164 mm2: 10.35 x 15.88(SSOP)
RatingCatalogCatalog
Schmitt TriggerNoNo
Technology FamilyABTABT
VCC(Max), В5.55.5
VCC(Min), В4.54.5
Voltage(Nom), В55
tpd @ Nom Voltage(Max), нс4.24.2
RoHSСовместимСовместим
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Quad Flatpack No-Lead Logic Packages (Rev. D)
    PDF, 1.0 Мб, Версия: D, Файл опубликован: 16 фев 2004
    Texas Instruments (TI) Quad Flatpack No-lead (QFN) 14/16/20-terminal Pb-free plastic packages meet dimensions specified in JEDEC standard MO-241 allow for board miniaturization and hold several advantages over traditional SOIC SSOP TSSOP and TVSOP packages. The packages are physically smaller have a smaller routing area improved thermal performance and improved electrical parasitics while
  • Advanced BiCMOS Technology (ABT) Logic Characterization Information (Rev. B)
    PDF, 528 Кб, Версия: B, Файл опубликован: 1 июн 1997
    The purpose of this document is to assist the designers of high-performance digital logic systems in using the advanced BiCMOS technology (ABT) logic family. Detailed electrical characteristics of these bus-interface devices are provided and tables and graphs have been included to compare specific parameters of the ABT family with those of other logic families. In addition typical data is provide
  • Advanced BiCMOS Technology (ABT) Logic Enables Optimal System Design (Rev. A)
    PDF, 115 Кб, Версия: A, Файл опубликован: 1 мар 1997
    Advanced bus-interface logic (ABIL) products processed in submicron advanced BiCMOS technologies (ABT) address the specific end-equipment demands of workstations personal and portable computers and telecommunications markets. This document discusses ABIL as system bus interfaces the merits of ABT its I/O structure packaging and ABT products for end-equipment specific solutions.
  • Family of Curves Demonstrating Output Skews for Advanced BiCMOS Devices (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 1 дек 1996
    This document shows the output skew for the ABT16254 ABT16952 and ABT16500A devices of the TI advanced BiCMOS (ABT) family. The data samples show which output skew is being examined where the data originates and how it is analyzed. Some errors present in the data are discussed. Skew curves at varying temperatures are given for the ABT16240 ABT16245 ABT16952 ABT16500A and ABT16249 devic
Серия: SN74ABTH162245 (2)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74ABTH162245
