Datasheet Texas Instruments SN74ACT2226 — Даташит
СерияSN74ACT2226
64 x 1 x 2 двойной независимой синхронной памяти FIFO
Dual 64 X 1, Dual 256 X 1 Clocked First-In, First-Out Memories datasheet
PDF, 809 Кб, Версия: C, Файл опубликован: 1 окт 1997
SN74ACT2226DWSN74ACT2226DWR
N12
Pin2424
Package TypeDWDW
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY252000
CarrierTUBELARGE T&R
МаркировкаACT2226ACT2226
Width (мм)7.57.5
Length (мм)15.415.4
Thickness (мм)2.352.35
Pitch (мм)1.271.27
Max Height (мм)2.652.65
Parameters / ModelsSN74ACT2226DW
SN74ACT2226DW
SN74ACT2226DWR
SN74ACT2226DWR
Package GroupSOICSOIC
Package Size: mm2:W x L, PKG24SOIC: 160 mm2: 10.3 x 15.5(SOIC)24SOIC: 160 mm2: 10.3 x 15.5(SOIC)
Schmitt TriggerNoNo
RoHSСовместимСовместим
  • FIFOs With A Word Width Of One Bit (Rev. A)
    PDF, 133 Кб, Версия: A, Файл опубликован: 1 мар 1996
    In digital systems data is continuously being exchanged between various subsystems. If the data arrives at differing speeds, intermediate storage is necessary. This intermediate storage works on a first-in, first-out (FIFO) basis. This document discusses the basics of FIFOs and gives and overview of their use in telecommunications applications, in modems with data compression, in DSP int
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
Серия: SN74ACT2226 (2)
  • Semiconductors> Logic> Flip-Flop/Latch/Register> FIFO Register
На английском языке: Datasheet Texas Instruments SN74ACT2226
