Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74ACT2228DWR — Даташит
СерияSN74ACT2228
МодельSN74ACT2228DWR
256 x 1 x 2 двойной независимой синхронной памяти FIFO 24-SOIC от -40 до 85
Dual 64 X 1, Dual 256 X 1 Clocked First-In, First-Out Memories datasheet
PDF, 809 Кб, Версия: C, Файл опубликован: 1 окт 1997
Pin24
Package TypeDW
Package QTY2000
МаркировкаACT2228
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
Package Size: mm2:W x L24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG
Schmitt TriggerNo
  • FIFOs With A Word Width Of One Bit (Rev. A)
    PDF, 133 Кб, Версия: A, Файл опубликован: 1 мар 1996
    In digital systems data is continuously being exchanged between various subsystems. If the data arrives at differing speeds, intermediate storage is necessary. This intermediate storage works on a first-in, first-out (FIFO) basis. This document discusses the basics of FIFOs and gives and overview of their use in telecommunications applications, in modems with data compression, in DSP int
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
Серия: SN74ACT2228 (2)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
На английском языке: Datasheet Texas Instruments SN74ACT2228DWR
