Datasheet Texas Instruments SN74ACT3622-20PQ — Даташит
СерияSN74ACT3622
МодельSN74ACT3622-20PQ
256 x 36 x 2 двунаправленная синхронная память FIFO 132-BQFP от 0 до 70
256 X 36 X 2 Clocked Bidirectional First-In, First-Out Memory (Rev. D)
PDF, 507 Кб, Версия: D, Файл опубликован: 1 апр 1998
14 предложений от 14 поставщиков
IC CLK DUAL FIFO MEMORY 132-QFP. Synchronous FIFO 18K (256 x 36 x 2) Bi-Directional 50MHz 13ns 132-BQFP (24.54x24.54). Logic -...
SN74ACT3622-20PQ
1 308 ₽
SUV System
SN74ACT3622-20PQ
SN74ACT3622-20PQ
SN74ACT3622-20PQ
Pin132
Package TypePQ
Industry STD TermBQFP
JEDEC CodeS-PQFP-G
Package QTY36
CarrierJEDEC TRAY (10+1)
МаркировкаACT3622-20
Width (мм)24.13
Length (мм)27.44
Thickness (мм)3.56
Pitch (мм).635
Max Height (мм)4.57
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • FIFO Mailbox-Bypass Registers: Using Bypass Registers to Initialize DMA Control (Rev. A)
    PDF, 65 Кб, Версия: A, Файл опубликован: 1 мар 1996
    The TI 32- and 36-bit FIFOs contain mailbox-bypass registers that transmit priority from one FIFO port to the other, port A to B or port B to A with out storing the data in the FIFO SRAM buffer. This document describes the FIFO mailbox-bypass registers and shows an example of direct memory access (DMA) control of a digital signal processor (DSP). The components described are the SN74ACT3641 and th
Серия: SN74ACT3622 (2)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT362220PQ, SN74ACT3622 20PQ
На английском языке: Datasheet Texas Instruments SN74ACT3622-20PQ
