Datasheet Texas Instruments SN74ACT3632-15PCB — Даташит
СерияSN74ACT3632
МодельSN74ACT3632-15PCB
512 x 36 x 2 двунаправленная синхронная память FIFO 120-HLQFP от 0 до 70
512 X 36 X 2 Clocked Bidirectional First-In, First-Out Memory datasheet
PDF, 497 Кб, Версия: D, Файл опубликован: 1 апр 1998
17 предложений от 17 поставщиков
IC BI-DIR FIFO MEMORY 120HLQFP. Synchronous FIFO 36K (512 x 36 x 2) Bi-Directional 66.7MHz 11ns 120-HLQFP (14x14). Logic - FIFOs...
SN74ACT3632-15PCB
5 004 ₽
Зенер
Россия и страны ТС
SN74ACT3632-15PCB
5 388 ₽
SUV System
SN74ACT3632-15PCB
SN74ACT3632-15PCB
Pin120
Package TypePCB
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (5+1)
МаркировкаACT3632-15
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).4
Max Height (мм)1.6
  • Interfacing TI Clocked FIFOs With TI Floating-Point DSPs (Rev. A)
    PDF, 108 Кб, Версия: A, Файл опубликован: 1 мар 1996
    FIFO memories are used in digital signal processing systems for matching data paths with asynchronous clock or data rates. This document shows the SN74ACT3632 512?36?2 clocked FIFO as a single-chip bi-directional buffering solution that interfaces to the TI TMS320C3x and TMS320C4x floating-point DSP family. Programmable FIFO flags enable DMA control techniques that are used to handle the data flow
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • FIFO Mailbox-Bypass Registers: Using Bypass Registers to Initialize DMA Control (Rev. A)
    PDF, 65 Кб, Версия: A, Файл опубликован: 1 мар 1996
    The TI 32- and 36-bit FIFOs contain mailbox-bypass registers that transmit priority from one FIFO port to the other, port A to B or port B to A with out storing the data in the FIFO SRAM buffer. This document describes the FIFO mailbox-bypass registers and shows an example of direct memory access (DMA) control of a digital signal processor (DSP). The components described are the SN74ACT3641 and th
  • Simultaneous-Switching Noise Analysis For Texas Instruments FIFO Products (Rev. A)
    PDF, 147 Кб, Версия: A, Файл опубликован: 1 мар 1996
    In the high-speed advanced logic families, including ACT and ABT FIFO products, analysis of circuit noise immunity during simultaneous switching of multiple outputs is crucial. This document provides a thorough explanation of noise reduction techniques for TI FIFO devices. It is designed to assist component and system design engineers in the evaluation of simultaneous switching noise for ACT and A
Серия: SN74ACT3632 (3)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT363215PCB, SN74ACT3632 15PCB
На английском языке: Datasheet Texas Instruments SN74ACT3632-15PCB
