Клеммники KEEN SIDE
Datasheet Texas Instruments SN74ACT3651-15PCB — Даташит
СерияSN74ACT3651
МодельSN74ACT3651-15PCB
2048 x 36 синхронная память FIFO 120-HLQFP от 0 до 70
2048 X 36 Clocked First-In, First-Out Memory (Rev. D)
PDF, 464 Кб, Версия: D, Файл опубликован: 17 фев 1999
IC CLOCKED FIFO MEMORY 120HLQFP. Synchronous FIFO 72K (2K x 36) Bi-Directional 66.7MHz 11ns 120-HLQFP (14x14). Logic - FIFOs Memory
SN74ACT3651-15PCB
2 230 ₽
SN74ACT3651-15PCB
2 708 ₽
727GS
SN74ACT3651-15PCB
SN74ACT3651-15PCB
Pin120
Package TypePCB
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (5+1)
МаркировкаACT3651-15
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).4
Max Height (мм)1.6
Approx. Price (US$)25.68 | 1ku
Package GroupHLQFP
Package Size: mm2:W x L (PKG)120HLQFP: 256 mm2: 16 x 16(HLQFP)
Schmitt TriggerNo
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • FIFO Mailbox-Bypass Registers: Using Bypass Registers to Initialize DMA Control (Rev. A)
    PDF, 65 Кб, Версия: A, Файл опубликован: 1 мар 1996
    The TI 32- and 36-bit FIFOs contain mailbox-bypass registers that transmit priority from one FIFO port to the other, port A to B or port B to A with out storing the data in the FIFO SRAM buffer. This document describes the FIFO mailbox-bypass registers and shows an example of direct memory access (DMA) control of a digital signal processor (DSP). The components described are the SN74ACT3641 and th
Серия: SN74ACT3651 (1)
  • SN74ACT3651-15PCB
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT365115PCB, SN74ACT3651 15PCB
На английском языке: Datasheet Texas Instruments SN74ACT3651-15PCB
