Datasheet Texas Instruments SN74ACT7802-25FN — Даташит
СерияSN74ACT7802
МодельSN74ACT7802-25FN
Асинхронная память FIFO 1024 X 18 68-PLCC от 0 до 70
1024 X 18 Strobed First-In, First-Out Memory datasheet
PDF, 193 Кб, Версия: D, Файл опубликован: 1 апр 1998
21 предложений от 18 поставщиков
IC ASYNC FIFO MEM 1024X18 68PLCC. Asynchronous FIFO 18K (1K x 18) Uni-Directional 40MHz 30ns 68-PLCC (24.23x24.23). Logic - FIFOs Memory...
SN74ACT7802-25FN
669 ₽
SN74ACT7802-25FN
770 ₽
SN74-ACT7802-25FN
Рутоника
SN74ACT7802-25FN
Pin6868
Package TypeFNFN
Industry STD TermPLCCPLCC
JEDEC CodeS-PQCC-JS-PQCC-J
Package QTY1818
CarrierTUBETUBE
МаркировкаSN74ACT7802-25FN
Width (мм)24.2324.23
Length (мм)24.2324.23
Thickness (мм)4.064.06
Pitch (мм)1.271.27
Max Height (мм)4.574.57
  • FIFO Memories: Solutions For Increasing Clock Rates And Data Widths (Rev. A)
    PDF, 95 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Four TI CMOS clocked first-in first-out (FIFO) memories the 2k?9 SN74ACT807, the 512?18 SN74ACT7803, the 256?18 SN74ACT7805, and the 64?18 SN748ACT7813 provide synchronous interfaces that conform to the requirements of many high-performance systems. The FIFO architecture limits the glue logic necessary and limits the timing constraints to the system. Each FIFO is easily expanded to accommodate var
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
Серия: SN74ACT7802 (2)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT780225FN, SN74ACT7802 25FN
На английском языке: Datasheet Texas Instruments SN74ACT7802-25FN
