Datasheet Texas Instruments SN74ACT7803-15DL — Даташит
| Серия | SN74ACT7803 |
| Модель | SN74ACT7803-15DL |
512 x 18 синхронная память FIFO 56-SSOP от 0 до 70
512 X 18 Clocked First-In, First-Out Memory datasheet
PDF, 410 Кб, Версия: C, Файл опубликован: 1 апр 1998
Купить SN74ACT7803-15DL на РадиоЛоцман.Цены — от 690 до 6 715 ₽19 предложений от 16 поставщиков Интегральные микросхемы Логические микросхемы - Кольцевые буферы FIFO | |||
| SN74ACT7803-15DL Texas Instruments | 2 330 ₽ | ||
| SN74ACT7803-15DL Texas Instruments | от 5 391 ₽ | ||
| SN74ACT7803-15DL Texas Instruments | по запросу | ||
| Pin | 56 |
| Package Type | DL |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 20 |
| Carrier | TUBE |
| Маркировка | ACT7803-15 |
| Width (мм) | 7.49 |
| Length (мм) | 18.41 |
| Thickness (мм) | 2.59 |
| Pitch (мм) | .635 |
| Max Height (мм) | 2.79 |
| Mechanical Data | Скачать |
- FIFO Memories: Solutions For Increasing Clock Rates And Data Widths (Rev. A)PDF, 95 Кб, Версия: A, Файл опубликован: 1 мар 1996
Four TI CMOS clocked first-in first-out (FIFO) memories the 2k?9 SN74ACT807, the 512?18 SN74ACT7803, the 256?18 SN74ACT7805, and the 64?18 SN748ACT7813 provide synchronous interfaces that conform to the requirements of many high-performance systems. The FIFO architecture limits the glue logic necessary and limits the timing constraints to the system. Each FIFO is easily expanded to accommodate var - Power-Dissipation Calculations for TI FIFO Products (Rev. A)PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36 - Simultaneous-Switching Noise Analysis For Texas Instruments FIFO Products (Rev. A)PDF, 147 Кб, Версия: A, Файл опубликован: 1 мар 1996
In the high-speed advanced logic families, including ACT and ABT FIFO products, analysis of circuit noise immunity during simultaneous switching of multiple outputs is crucial. This document provides a thorough explanation of noise reduction techniques for TI FIFO devices. It is designed to assist component and system design engineers in the evaluation of simultaneous switching noise for ACT and A
Серия: SN74ACT7803 (2)
- SN74ACT7803-15DL SN74ACT7803-25DL
- Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT780315DL, SN74ACT7803 15DL
