Datasheet Texas Instruments SN74ACT7813 — Даташит
СерияSN74ACT7813
Синхронная память FIFO 64 x 18
64 X 18 Clocked First-In, First-Out Memory datasheet
PDF, 412 Кб, Версия: B, Файл опубликован: 1 апр 1998
SN74ACT7813-15DLSN74ACT7813-20DL
N12
Pin5656
Package TypeDLDL
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY2020
CarrierTUBETUBE
МаркировкаACT7813-15ACT7813-20
Width (мм)7.497.49
Length (мм)18.4118.41
Thickness (мм)2.592.59
Pitch (мм).635.635
Max Height (мм)2.792.79
RoHSСовместимСовместим
  • FIFO Memories: Solutions For Increasing Clock Rates And Data Widths (Rev. A)
    PDF, 95 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Four TI CMOS clocked first-in first-out (FIFO) memories the 2k?9 SN74ACT807, the 512?18 SN74ACT7803, the 256?18 SN74ACT7805, and the 64?18 SN748ACT7813 provide synchronous interfaces that conform to the requirements of many high-performance systems. The FIFO architecture limits the glue logic necessary and limits the timing constraints to the system. Each FIFO is easily expanded to accommodate var
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
Серия: SN74ACT7813 (2)
  • Semiconductors> Logic> Flip-Flop/Latch/Register> FIFO Register
На английском языке: Datasheet Texas Instruments SN74ACT7813
