Datasheet Texas Instruments SN74ACT7814-20DL — Даташит
СерияSN74ACT7814
МодельSN74ACT7814-20DL
Асинхронная память FIFO 64 x 18 56-SSOP от 0 до 70
64 X 18 Strobed First-In, First-Out Memory datasheet
PDF, 207 Кб, Версия: C, Файл опубликован: 1 апр 1998
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY20
МаркировкаACT7814-20
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
  • FIFO Memories: Solutions For Increasing Clock Rates And Data Widths (Rev. A)
    PDF, 95 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Four TI CMOS clocked first-in first-out (FIFO) memories the 2k?9 SN74ACT807, the 512?18 SN74ACT7803, the 256?18 SN74ACT7805, and the 64?18 SN748ACT7813 provide synchronous interfaces that conform to the requirements of many high-performance systems. The FIFO architecture limits the glue logic necessary and limits the timing constraints to the system. Each FIFO is easily expanded to accommodate var
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • Simultaneous-Switching Noise Analysis For Texas Instruments FIFO Products (Rev. A)
    PDF, 147 Кб, Версия: A, Файл опубликован: 1 мар 1996
    In the high-speed advanced logic families, including ACT and ABT FIFO products, analysis of circuit noise immunity during simultaneous switching of multiple outputs is crucial. This document provides a thorough explanation of noise reduction techniques for TI FIFO devices. It is designed to assist component and system design engineers in the evaluation of simultaneous switching noise for ACT and A
Серия: SN74ACT7814 (2)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74ACT781420DL, SN74ACT7814 20DL
На английском языке: Datasheet Texas Instruments SN74ACT7814-20DL
