Datasheet Texas Instruments V62/14605-01XE — Даташит
СерияSN74AHC1G126-EP
МодельV62/14605-01XE
Буферный вентиль с одной шиной и выходом с 3 состояниями, SN74AHC1G126-EP 5-SC70 от -55 до 125
Single Bus Buffer Gate With 3-State Output, SN74AHC1G126-EP datasheet
PDF, 759 Кб, Файл опубликован: 11 дек 2013
Микросхема Логический чип, Buffer/Line Driver 1CH Non-Inverting 3-ST CMOS 5Pin SC-70 T/R
V62/14605-01XE
116 ₽
V62/14605-01XE
337 ₽
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY250
CarrierSMALL T&R
МаркировкаSLI
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputYes
Bits1
F @ Nom Voltage(Max)75 Mhz
Gate TypeBUFFER
ICC @ Nom Voltage(Max)0.01 мА
Тип входаCMOS
LogicTrue
Output Drive (IOL/IOH)(Max)50/-50 мА
Тип выходаCMOS
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)13,8.5 нс
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74AHC1G126-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Little Logic Products
V62/1460501XE, V62/14605 01XE
На английском языке: Datasheet Texas Instruments V62/14605-01XE
Публикации по теме
