Datasheet Texas Instruments SN74AHCT1G04-Q1 — Даташит
СерияSN74AHCT1G04-Q1
Автомобильный каталог Одиночные инверторные ворота
Single Inverter Gate datasheet
PDF, 215 Кб, Версия: A, Файл опубликован: 7 фев 2008
CAHCT1G04QDCKRG4Q1CAHCT1G04QDCKRQ1
Доступность образцов у производителяДаНет
N12
Pin55
Package TypeDCKDCK
Industry STD TermSOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаBCSBCS
Width (мм)1.251.25
Length (мм)22
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)1.11.1
Parameters / ModelsCAHCT1G04QDCKRG4Q1
CAHCT1G04QDCKRG4Q1
CAHCT1G04QDCKRQ1
CAHCT1G04QDCKRQ1
3-State OutputNoNo
Bits11
F @ Nom Voltage(Max), Mhz7575
Gate TypeINVERTER BUFFERINVERTER BUFFER
ICC @ Nom Voltage(Max), мА0.010.01
LogicInvertingInverting
Рабочий диапазон температур, Cот -40 до 125от -40 до 125
Output Drive (IOL/IOH)(Max), мА8/-88/-8
Package GroupSC70SC70
Package Size: mm2:W x L, PKG5SC70: 4 mm2: 2.1 x 2(SC70)5SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotiveAutomotive
Schmitt TriggerNoNo
Special FeaturesDown translation to Vcc,low power,TTL compliantDown translation to Vcc,low power,TTL compliant
Sub-FamilyInverting Buffer/DriverInverting Buffer/Driver
Technology FamilyAHCTAHCT
VCC(Max), В5.55.5
VCC(Min), В4.54.5
Voltage(Nom), В55
tpd @ Nom Voltage(Max), нс7.57.5
RoHSСовместимСовместим
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
Серия: SN74AHCT1G04-Q1 (2)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74AHCT1G04-Q1
Публикации по теме
