Datasheet Texas Instruments SN74AHCT1G86-Q1 — Даташит
СерияSN74AHCT1G86-Q1
Каталог автомобилей Одиночный вентиль «исключающее ИЛИ» с 2 входами
SN74AHCT1G86Q-Q1, SINGLE 2-INPUT EXCLUSIVE-OR GATE datasheet
PDF, 805 Кб, Файл опубликован: 29 дек 2010
CAHCT1G86QDCKRQ1
Статус продуктаВ производстве
CAHCT1G86QDCKRQ1
N1
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаB5S
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Parameters / ModelsCAHCT1G86QDCKRQ1
CAHCT1G86QDCKRQ1
3-State OutputNo
Bits1
F @ Nom Voltage(Max), Mhz75
Gate TypeXOR
ICC @ Nom Voltage(Max), мА0.01
LogicTrue
Рабочий диапазон температур, Cот -40 до 125
Output Drive (IOL/IOH)(Max), мА8/-8
Package GroupSC70
Package Size: mm2:W x L, PKG5SC70: 4 mm2: 2.1 x 2(SC70)
RatingAutomotive
Schmitt TriggerNo
Special FeaturesDown translation to Vcc,low power,TTL compliant
Sub-FamilyXOR Gate
Technology FamilyAHCT
VCC(Max), В5.5
VCC(Min), В4.5
Voltage(Nom), В5
tpd @ Nom Voltage(Max), нс8
CAHCT1G86QDCKRQ1
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
Серия: SN74AHCT1G86-Q1 (1)
  • Semiconductors> Logic> Little Logic
На английском языке: Datasheet Texas Instruments SN74AHCT1G86-Q1
Публикации по теме
