Datasheet Texas Instruments CALVC164245MDGGREP — Даташит
СерияSN74ALVC164245-EP
МодельCALVC164245MDGGREP
Усовершенствованный продукт, 16-битный трансивер со сдвигом уровня от 2,5 до 3,3 В/3,3 до 5 В, 3 состояния, 48-TSSOP от -55 до 125
SN74ALVC164245-EP datasheet
PDF, 381 Кб, Версия: A, Файл опубликован: 20 сен 2005
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаC164245MEP
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.04 мА
ICCA Static Current0.04 мА
ICCB Static Current0.04 мА
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
RatingHiRel Enhanced Product
Technology FamilyALVC
VCC(Max)5.5 В
VCC(Min)2.3 В
VCCA(Max)3.6 В
VCCA(Min)2.3 В
VCCB(Max)5.5 В
VCCB(Min)3 В
tpd @ Nom Voltage(Max)7.6,5.8 нс
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Semiconductors > Space & High Reliability > Logic Products > Voltage Level Translation Products
На английском языке: Datasheet Texas Instruments CALVC164245MDGGREP
Публикации по теме
