Datasheet Texas Instruments V62/05612-01XE — Даташит
СерияSN74ALVC164245-EP
МодельV62/05612-01XE
Усовершенствованный продукт, 16-разрядный трансивер со сдвигом уровня, 2,5–3,3 В/3,3–5 В, 3 состояния, 48-SSOP, от -40 до 85
SN74ALVC164245-EP datasheet
PDF, 381 Кб, Версия: A, Файл опубликован: 20 сен 2005
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаALVC164245
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.04 мА
ICCA Static Current0.04 мА
ICCB Static Current0.04 мА
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
RatingHiRel Enhanced Product
Technology FamilyALVC
VCC(Max)5.5 В
VCC(Min)2.3 В
VCCA(Max)3.6 В
VCCA(Min)2.3 В
VCCB(Max)5.5 В
VCCB(Min)3 В
tpd @ Nom Voltage(Max)7.6,5.8 нс
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • Semiconductors > Space & High Reliability > Logic Products > Voltage Level Translation Products
V62/0561201XE, V62/05612 01XE
На английском языке: Datasheet Texas Instruments V62/05612-01XE
Публикации по теме
