Клеммные колодки Keen Side
Datasheet Texas Instruments SN74ALVC7806 — Даташит
СерияSN74ALVC7806
Асинхронная память FIFO 256 x 18, 3,3 В
256 X 18 Low-Power First-In, First-Out Memory datasheet
PDF, 187 Кб, Версия: A, Файл опубликован: 1 апр 1998
SN74ALVC7806-25DLSN74ALVC7806-40DL
N12
Pin5656
Package TypeDLDL
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY2020
CarrierTUBETUBE
МаркировкаALVC7806-25ALVC7806-40
Width (мм)7.497.49
Length (мм)18.4118.41
Thickness (мм)2.592.59
Pitch (мм).635.635
Max Height (мм)2.792.79
RoHSСовместимСовместим
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74ALVC7806 (2)
  • Semiconductors> Logic> Flip-Flop/Latch/Register> FIFO Register
На английском языке: Datasheet Texas Instruments SN74ALVC7806
