Datasheet Texas Instruments SN74ALVCF162834 — Даташит
СерияSN74ALVCF162834
18-битный универсальный драйвер шины CMOS 3,3 В с выходами с 3 состояниями
SN74ALVCF162834 datasheet
PDF, 142 Кб, Версия: B, Файл опубликован: 31 авг 2004
SN74ALVCF162834DL
Статус продуктаВ производстве
SN74ALVCF162834DL
N1
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY20
МаркировкаALVCF162834
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Parameters / ModelsSN74ALVCF162834DL
SN74ALVCF162834DL
F @ Nom Voltage(Max), Mhz150
ICC @ Nom Voltage(Max), мА0.04
Рабочий диапазон температур, Cот -40 до 85
Package GroupSSOP
Package Size: mm2:W x L, PKG56SSOP: 191 mm2: 10.35 x 18.42(SSOP)
Schmitt TriggerNo
Technology FamilyALVC
VCC(Max), В3.6
VCC(Min), В2.3
Voltage(Nom), В2.5,2.7,3.3
tpd @ Nom Voltage(Max), нс4,4.6,3.5
SN74ALVCF162834DL
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
Серия: SN74ALVCF162834 (1)
  • Semiconductors> Logic> Universal Bus Function> Universal Bus Driver (UBD)
На английском языке: Datasheet Texas Instruments SN74ALVCF162834
